4- 74 duster 14in. hubcaps,all nice-$25.00
74 Duster frt. signal lens,clear, 1 real nice, 1 has couple small cracks-$14.00pr.
74 Dart trunk latch mechanism and body latch- $ 10.00
74 Dart qtr panel extensions-
( above tailights)- $20.00 pr.
74 Dart hood latch and secondary latch- $ 16.00
74 Dart hood latch support panel -$15.00
74 Dart Front bumper, no rust thru,
no dents, no twists, needs chrome -$55.00
74 Dart rocker panel mouldings, with clips, -$30.00pr.
74 Dart 4dr. vinyl top qtr panel to roof trim -$15.00pr.
74 Dart 4 dr. A-pillar covers, beige-gold color,-$12.00 pr.
74 Dart 4 dr B-pillar chrome-stainless covers, nice shape,-$20.00pr.
74 Dart 4 dr.arm rest bases, tan color, -$ 13.00 all 4.
74 Dart 4 dr. back glass -$25.00 ea.
74 Dart doors for 4 dr - $ 25.00 ea.
74 Dart 4 dr. windshield chrome trim, nice, -$ 15.00
74 Dart 4 dr. aluminum front entrance step plates- $ 8.00
74 A-body Dart 4 dr.straight wiper arms-$12.00pr.
74 Dart front bumper guards,good rubber pcs., peeling chrome, -$25.00
74 Dart REAR bumper guards, good rubber pcs., peeling chrome,- $25.00
74 Dart gray rubber filler above Front bumper, (under grill) nice shape- $40.00
74 Dart gray rubber filler above rear bumper, 3pcs. nice shape- $35.00
74 A-body 318 engine mounts- spool type- $35.00
74 A-body 318-360 valve covers, nice -$40.00
74 A-body 318 exhaust manifolds, with heat stove, -$85.00
74 A-body 318 air cleaner, -$20.00
74 A-body V-8 4 blade solid fan,-$14.00
74 A-body gas tank straps- $ 15.00pr.
74 A-body complete ash tray,door and lighter,-$12.00
74 A-body glove box door, woodgrain style,chrome faded, -$12.00
74 A-body headlight switch-$12.00
74 A-body tan kick panels, -$ 15.00pr.
74 A-body tan-gold sunvisors,-$ 20.00pr.
74 A-body metal dash frame,bare, -$25.00
74 A-body under steering colunm cover plate, gold plastic -$9.00
74 A-body Dart tailight wiring harness,- $20.00
74 A-body wiper linkage, clips are bad,-$ 12.00
74 A-body drivers side vent assembly, - $20.00
74 A-body heater box assembly, no A/C, -$35.00
74 A-body throttle pedal assembly,-$ 14.00
74 A-body emission part: says "carb" on it and mounts to air cleaner, with hoses -$14.00
74 A-body pass side front fender to bumper bracket support brace- $9.00
74 A-body small block heat stove- $ 22.00
74 A-body manual disc brake master cylinder - $19.00
74 A-body emergency brake mechanism and handle, -$ 25.00
74 A-body driver side under frame rail starter splash shield -$22.00
74 A-body colunm shift linkage to auto. trans- $25.00
74 A-body Dart plastic inner fender splash shields - $ 20.00pr.
74 A-body under hood stabilizer bars -$13.00pr.
74 A-body plastic splash shields around K-frame,-$22.00 pr.
74 A-body headlight buckets,stainless trim rings and headlight bulbs -$22.00
74 A-body charcoal cannister w/ mounting bracket -$16.00
74 A-body-Dart trunk lock, no key-$8.00
74 A-body big bolt pattern 7 1/4 rearend , complete -$ 85.00
74 A-body 904 trans-tailshaft counterweight, -$10.00
74 A-body 318-904 trans bolts and braces,- $13.00
74 Dart tailight panel Aluminum insert,
( faded, no dents)- $15.00
74 A-body ( DART ) bumper jack,
also comes with lug wrench.
$50.00 plus shipping
located parkersburg, WV
