draginmopars
I had a leaking brake hose on the passengers front
replaced the hose, bleed the system, check adjustment on all 4 wheels
Now, when first pump of the brake
goes almost to the floor
multiple pumps pedal comes up, holds pressure
release brake pedal
1 pump does the same thing > goes to floor
brakes were fine before, except for hose was wet at fitting
??? Do I still have air in the system???
Double checked the brake shoe adjustment
check master cylinder this morning > still full
thanks
release brake pedal
thanks
