Low First Gear 904?
340inabbody
Arizona
Hey guys. I thought I heard that someone was running a “low first gear 904”. Can someone explain what that is? Was that a specific factory model type or a modified first gear?
The wide ratio version of the A-904 was introduced in all Chrysler domestic rear wheel drive cars for the 1981 model year, both A-904 and A-998 variants. It was also introduced into the trucks using the A-904T and A-998. The new gear ratio set was released to work with the higher ratio (lower numerically) rear axles for better fuel economy in eight cylinder applications and improved performance in six cylinder applications.
The new wide ratio set changed the first and second gear ratio as shown in the following table:
Gear1981 WIde-Ratio Gear RatiosPrevious Standard Gear Ratios
1st2.74:12.45:1
2nd1.54:11.45:1
3rd1.00:11.00:1
Reverse2.21:12.21:1
The change included a new front planetary and ring gear set, sun gear with sun shell, with matching bushings and thrust washers.
The wide ratio version of the A-904 was introduced in all Chrysler domestic rear wheel drive cars for the 1981 model year, both A-904 and A-998 variants. The new gear ratio set was released to work with the higher ratio (lower numerically) rear axles for better fuel economy in eight cylinder applications and improved performance in six cylinder applications.
1st2.74:12.45:1
2nd1.54:11.45:1
3rd1.00:11.00:1
Reverse2.21:12.21:1
Thanks! So thats a completely different gear set. Ate TCI’s and other aftermarket trans run their own gear ratios or do they use factory ratios?
I haven't used any aftermarket stuff, but from what I've seen, some make their own, and some refurbish or reinforce factory parts. What I have seen listed is just the factory ratios. It can be added to earlier transmissions.
I believe a lot of the OEM low gear transmissions also had lock-up converters which don't interchange with regular converters. But they can be swapped into regular 904s if you know what parts to swap (including valve body?). Not sure what aftermarket low gears were made for a 904 but I've seen 2.77 and something like 2.30...something for 727s. Very expensive.
I used OEM 2.74 gearsets in my Dart Sport 904s. More gear usually helps heavier vehicles and smaller less torquey engines in drag racing.
That’s kind of why I’m asking. My 340 is in a Bbody 1970 satellite which is 2 to 300 pounds more than an Abody.
What irony....
I asked a similar question just a few minutes ago on this forum. I didn't know that THIS thread was started a couple hours before me.
I have a 904 in my Dart, it was in my '70 Charger when I got the car in 2000. I wondered if it were a low gear version but wondered if ALL low gear versions came with lockup converters because mine is not one. I'd just look up the numbers but my transmission has none stamped where they are usually found.
