Stock pickup? If so, then it can set on the bottom of the pan and be OK; it draws through the side opening, not the bottom.
Can you share some actual pressure readings? 45-55 psi stone cold at low idle would be possible for the lower pump spring pressure.
Standard main bearings with groove on the top half only? Actual bearing clearances that were set/found? We're just checking everything but can't do that without actual info provided by you.
And there are plugs on the front and rear of the 2 oil galleries that can get left out. The one in front of the distributor shaft is the most common to get left out but the 2 in front are also forgotten with varying results.
The filter bypass or drain back are not at all likely.
Did you use ARP main studs by any chance? They are problematic for jacking up one side of the oil pump mounting to the rear main cap.
