Good afternoon, everybody. I’ve got this set up on an a904, age unknown. All I know about this thing is that it has the small bore servos which I understand to be a pre-1972 trans. Anyhow, manuals claim that the band adjustment is 72in lbs. I’ve heard the turn out is 2-4 turns, but even still, the band is far too tight. With the air check, there is little to no response movement on the clutch drum. At 6 turns, I am seeing results, but I am well beyond the 72in lbs spec. This worries me, and manuals/videos are useless for this type of arm is not the usual. Any tips or advice?
