hotrod swinger
1973 Dart Swinger, basically factory wiring.
Noticed low voltage while driving, a few minutes later voltmeter stays at 12.5, no charge.
Verified with multimeter.
I have battery voltage at the alternator stud.
I removed the green wire from the alternator and grounded the field connection, started the car and the alternator started charging again.
Where do I go from here? Is there a further test for the voltage regulator I can do?
