Kenflo
I have a question about the charging system. Since I rewired the car I have always had a fairly low voltage reading (at least I think it’s low) on the volt gauge in the dash. When at idle 900RPM the gauge is reading 12 volts, when cruising around town 11.8-12 volts. Battery is about 3 years old and I think is ok tests at 12.6 prior to starting. I should mention when the car is between uses battery is always hooked up to a smart charger/maintainer. Alternator is the power master 7018 75 amp. Used EZ wire kit to wire the entire car.
Is this voltage too low? I am concerned that the battery is not charging
