Lower Control Arm Help
bhenry
Member
denver
I have a bent lower control arm on my 1970 Dodge Dart. I have been looking for a replacement and I'm coming up with mixed info from different people. Can someone tell me what year range of A Body cars that will have the same lower control arm? I have told 1967-1972 and also 1967-1976........... not sure what will work. Any help would be great.
I believe the lower control arms are basically the same '67-'76 the difference being the position of the sway bar tabs if applicable. The confusion probably stems from the upper A-arms '73< with discs use the larger ball joint .
+1 If you don't run a sway bar then they are the same. More than likely you will have to buy the set and not just one, so they will match anyway.
Thanks for confirming this info Badart.
Bhenry
If you haven't found a replacement yet pm me I have a set off a low mileage '73 /6 dart also if the control arm was bent how is the strut rod?
The strut rod is ok, just bent right were the lower ball joint connects . Thanks for all the info.
Jomoper, I have a friend that may have one. If that does not work out I will pm you. I should know by the weekend. Thanks!
