Lower control arm pivit pin
Waco Demon
Waco Tx
I installed the lower control arm pivot pin and bushing from Performance Suspension Technology . Now with the strut rod and bushing installed the lower control arm dose not go all the way on the pivot pin . About 3/8" gap control arm and K frame
Waco Demon
Post a pic. The last bit of the pin is nearly an interference fit into the k-member.
Is that the poly bushing set up that uses the original bushing housing? If so might did the same thing, it didn't slide all the way in the bushing. But i haven't had a problem because of it yet.
It is PST's new pin and poly graphite bushings I took the whole frontend apart and started over now the RH side is close but the driver has 1/4" gap . Pivot pin locked down and there is a 1/4" between pin and bushing
Waco Demon
