lower control arm 'shaft' question...
95teetee
Drumheller, Alberta
ok, I need to replace one of these as circled in the picture(the actual bushing pressed into the LCA):
does anyone know the correct term? Can't find anything (on Rock Auto, for instance)...or better yet, any chance anyone has a part number?
TIA
that was quick-thanks airkiller- I'll check them out (hoping to just change the bushing for now- I wanna get this car done:D)
btw, I don't see the bushings- did yours come with them?
edit- "control arm pivot shaft"-thanks again, ak.
edit again- now that I know the correct term, I found 'Moog K791' so hopefully I can use that as a reference point...
yep, now that I have that number I was able to find it on Rock auto- we had actually looked at that earlier, but didn't realize it was the correct part
thanks guys...
