Lower Control arm Tools
You can get a 12 ton shop press from Harbor Freight or Walmart or Amazon for $100 or less that would do what you need to do. It's just a frame with a bottle jack and the bottle jack can be replaced if yours ever wears out. I bought one probably 30 years ago. Don't use it very often, but when I need one, it's indispensable.
I got the big tap from ebay for cheap. Still takes muscle to screw it into the bushing shell, but it's a lot easier and cleaner than the hammer and chisel method I used to use.
I have the Mancini tool.
With the arms laying on the work bench, it takes less the 5 minutes to remove both of them.
Putting them together, we have a big press at work, it makes quick work of them.
Lets put a patton on it , it looks like it could do the job. ButI still need the tool to get pivot shaft out? Not big on spending a small fortune on a large tap and still have to use a press of which I don't have.
As cheap as light duty shop presses are, there is really no excuse not to have one. If you have an older car, it may as well be a prerequisite. Get a harbor freight coupon and go get one. They are cheap but if you keep them lubed and take care of them, they will do the job.
Naw they ain't that cheap. Not anymore. The HF 12 press is 169 with no coupon. But my God, they pay for themselves very quickly.
Yup.
No special tools needed, though on some applications I can make use of my c frame from my ball joints press. More on putting the new ones in than to remove the old ones. I've seen a real similar c clamp type tool over the years made for control arm bushings but have never gotten to try one.
I've had lots of "black rubber marshmallow" fires in my gravel driveway, burning out bushings over the years. Then an air chisel walked around the circumference of the old bushing shell as far as I can without hitting the control arm itself to collapse it into itself and they fall out.
Though lately the last handful of control arm bushing jobs I've done I've needed to leave the old shell in place as I have taken a liking to urethane, and they usually don't come with shells. I've gone and bought the cheapest new bushings I can get and burnt them out when I've forgotten that I need the shell for the new bushings.
I do have a 15 ton press of my own and use it often/ but rarely for control arm bushings.
Ive done the tap method several times.
You can use a gear puller to push the pin out and a combat screwdriver to get the rubber out.
I bought a press, you can probably find one on Craigslist if you have a budget.
What size tap did you use for this LCA Shaft bushing and is it the same for the UCA bushings? Thanks in advance.
Both are a waste of money. The UCA tool, while it works well, can be replicated for about $10 at the hardware store
That there is all you need.
The LCA tool, well, maybe it works on some easy ones but if you’ve got a tough case it’ll just strip the bolt.
The 1 3/8” tap and a small press works FAR better. The tap you can usually pick up for around $20 used on eBay. A 12 ton HF press with a coupon and the tap and home made UCA tool and you’re probably not out much more than the Mancini tools. And you’ve got a press that can be used for all sorts of other jobs.
american muscle makes the tools that mancini sells. they're okay for a hobby wrencher or enthusiast but don't last for nothing-- the threads gow out and washers get all bendy and galled.
the setup that 72blu posted is the jam for UCA bushings and the price is right.
on the LCA there's a bunch of ways to tackle that job: welding a washer to the bushing cup, cutting the cup and getting after it with an air hammer or cold chisel, collapsing it on itself and punching it out from the back. but the tap is the absolute easiest and safest out of the bunch.
can't recommend a press enough, not only for suspension work but just in general. although, don't mess around trying to press in the upper bushings, you'll likely bend the arm rendering it junk.
Not sure about this but didn't American Muscle go out of business some years ago and some other company started making some of their tools.
Ran into the same problem with the bolts and washers. Solved that problem by replacing with grade 8 fasteners and applying grease to the threads.
Of course there's nothing wrong with making you're own tools if you want to go that route.
Totally agree. While you can definitely use a press on the UCA bushings it takes some careful blocking to make sure you don’t bend anything. I prefer using the homemade tool posted above even having a press, it’s much faster and it’s harder to damage the UCA that way.
Realistically, a tube like what you need for the tool is the best way to support the UCA to press the bushing, and if you’ve got that already then you’ve got most of what you need to make the tool!
No, not until i croak, and then somebody will definitely have to liquidate all my tools, and possessions.
I have tools similar to the miller tool. I can’t figure out how the two collars attach to the casing in the lower control are. The two collars attach to the casing of the bushing? I am not sure how to pull the casing with these tools.
Thank you very much!
Any time. I did have to mill the "catching" edge down thinner, than as recieved from Mancini, to get into the recessed area on one set that I did. As received it was too thick to fit in the gap between sleeve shell and the bottom of the lca hole. Once you tighten the nut up you then use the slide hammer or press it out.
I was thinking the long pipe and long screw would pull it out. I didn’t get it from Mancini. In fact I am very pissed at them. He sent me pivots and insisted that they were for A bodies after I told him they do not fit. Had to go to Kanter for the pivots and the LCA bushings. Kanter told me I got B/C Body pivots. Mancini won’t own the problem. And I bought a lot of parts from them. 50 years ago when I worked on NYC cabs you got a new LCA with the bushings and slapped the parts in. We didn’t press parts in took too long the cab drivers wanted out of the shop forthwith:))
Re pressing stuff in and out, does anyone know of a kit with adapters? I have the 12-ton Harbor Freight, but it has just a ~3/4"D rod which extends below the moving table. I keep a bucket of old parts, like steel sprockets, washers, and tubes to find an adapter that fits the part, but tedious rigging something up. I also dig into the assorted disks and sleeves in my C-clamp ball-joint press. Seems Harbor Freight or another would offer basic adapters. One useful one would be a set of milk-stools. I welded one up with 3 bolts angled between two thick steel rings (Ace Hardware) to press down a spring disk in my Chrysler A-604 transmission, while leaving room to slide the snap ring into the groove. Indeed, I saw a youtube where a guy in Mexico fabbed one almost identical (great minds and all that?).
