lower control arms
river rat
Houston, TX
Besides the normal a-body ones, will any of the b-body lower control arms fit a 67 barracuda?
B body arms won't work, but you should have no trouble welding tabs on the arms you have now. This would be a great time to box them too.
I do know for a fact ( as I have both) that A-Body LCA's are 3/16" longer than E-Body LCA's. I believe ( not 100% sure) that E-Body70-74 and B-Body70-72 are the same length, Not sure about earlier B-Body's?
I was specifically looking at 66-69 b-bodies.
Getting ready to rebuild the front end, and thought about replacing the lca with ones that have a sway-bar tab.
Yeah..You are best off sticking with the A-body stuff.
Good luck with your search.
Those will not fit also. They are the same length as 70-74 E-bodies and 70-72 B-bodies.
BTW, all 66-72 B-body and all E-body LCA interchange IF they don't have sway bars on them. The only difference is the sway bar tab if equipped or used.
