vwmoparguy
On my 65 Dart I have removed the front suspension for powder coating. I noticed on the LCA, on the part that rotates, there is a rubber bushing. Is there a way to remove the torsion bar pivot from the LCA?
Ok, I got everything pressed apart with no problems. The next question is....has anyone powder coated the LCA's? Seems it will interfere with the rotating operation of the LCA and torsion pivot?????
Our very own powder coating guru -Leanna (from Phoenix Specialty Coatings)
did a set for me and the pivot rotates just fine!
http://www.moparmusclemagazine.com/tipstricks/155_0306_control_arms/index.html
Read this tech article. Good information.
