71DartGuy
Someone clear this up for me please. When doing a disk brake swap on a 71 dart, do I need to replace the entire LCA or just put in the bigger ball joint? I would think both, but I'm not sure. Thanks
The disc brake spindle will sit right onto the drum brake lower ball joint but... betcha you can't seperate them without distroying the boots and probably need new lower joints anyway. .875 travel in end play is the wear limit.
