Lunati cam inquiry
Used one in a duster340. Had hookers,ld340,1.88x1.60 stock heads and a 750dp , went 13.1@104 = nice street cam with just a little chop.
Anyone here run this cam in a 360?
Voodoo Hydraulic Flat Tappet Cam & Lifter Kit - Chrysler 273-360 268/276 - Lunati Power
I really was looking for a mechanical flat tappet, but this one keeps bugging me.
Hello Everybody
I have to revive this thread because I looking also for this Lunati Voodoo Cam for my
LA 360 with J Heads .
Was there any problems with this Cam about Piston / Valves damaged ( timing ) ?
Can anybody tell me more about the Performance with this Cam ?
Maybe with a Dyno ?
Thx for answer and help
Hello Everybody
Maybe with a Dyno ?
That cam shouldn't be any problem with most any piston because it doesn't have a lot of lift. No hp #'s on that one but I used the next one bigger in a 360 with mildly worked over X heads and made 360 hp. The one your looking at should be a real nice street performance cam
Thx for answer
I had a Stock 360 engine block with Stock Pistons . Want to but a ported and Performed J Head with 2.02 intake valves on it with this Lunati cam and hope that it makes +/- 350 hp with the Holley 650 double pump carb and the weiand 7505 intake manifold .
