Dustine
Member
Just curious if a M1 DP 340 replica intake is an upgrade over the factory 340 cast iron intake ? I know with it being aluminum there is a big weight savings but is there a noticeable power gain by making the switch ? The intakes look identical other than one being cast iron and one aluminum. My setup is a stock 72 340 factory exhaust manifolds 904 auto 3:23 SG Eddy 600 pretty much how it left the factory except the carb . I do have a set of 3:91’s I plan on putting in soon hopefully to wake it up a bit
