[SOLD] M1 big block intake
rtdodge1
north caroilna
What I have here is a new m1 big block manifold for use with stage v1 heads on a RB engine. part# showed in pic. $200 plus ride.
Ok, so I was thinking stage 6 aluminum heads. But It fits the max wedge that is the same width as the 440. So then I’ll have to pass as it’s not the 1 I need. Thanks. Kim
This is from memory but IIRC an RB intake is used on the B wedge with the Stage VI heads. The RB running Stage VIs used either this wider manifold, or spacers and the std RB intake. Could be wrong but I think that was it.
The stage v1 head intake ports are raised . Thus taking a different intake to match the heads. This intake fits the RB engine.
I have a 400 based 470 stroker with stage6 heads. RB intake bolts right on no problem. So then ur intake is standard port or max wedge port. Can u measure the ports. I want to be able to bolt the intake on to a RB stroker with no spacers. Kim
This intake is for a RB engine with stage V1 heads with standard port size.
I was interested too, I have cnc`d standard , raised port heads w/ a little custom fitting around the port entrance .
Not max wedge ----------
