m1 intake gaskets
I don't use the paper gaskets and haven't had a problem but it depends on your heads and how it fits. If the intke "settles" down into the valley and the bolts don't start easilly, using the paper above the valley pan will help. I believe using the paper below it make lead to an oil leak unless you use a bit of silicone to seal the corners.
i don't use the paper gaskets and haven't had a problem but it depends on your heads and how it fits. If the intke "settles" down into the valley and the bolts don't start easilly, using the paper above the valley pan will help. I believe using the paper below it make lead to an oil leak unless you use a bit of silicone to seal the corners.
x2
