moparboy340
Member
Hello everyone,
Not new to the forum, but I do not do alot of posting, usually just read others posts and builds, but this time I cannot find the answer I am looking for.
I have a Magnum 360 Block, I am trying to gather all the parts I want for my new build. I found a Camshaft from Lunati Voodoo that has the specs I would like to use with my combo. It is a Hyd. Roller.
My question is can I use an LA hyd. Roller cam in a Magnum Block, using Magnum Roller lifters?
I will be using LA style front timing cover so I am not worried about clearance due to Fuel Pump snout.
Can anyone shed any light on this, I tried searching and could not find any reason it would not work both are 59 degree block and the cam specs seem to be the same for LA and Magnum.
