Hey guys
A friend of mine is running a 360 Magnum with EQ heads. It has around 360 hp at the flywheel. What would be a good plug for the eq heads and should he go one heat range cooler at that hp. The cheapest and most common plug here in Australia is the NGK brand.
Cheers
Cheers
