magnum exhaust
moparmarkk
milton,fl.
Hi, will the stainless steel tubular header from a 5.9 magnum fit a LA engine? and if so will these pipes work in a 75 A-body with 318-360? thanks , mark
Magnum exhaust ports are small like 273/318 heads. Some early 340/360 heads have exhaust ports that are larger. You should check if using the early 340/360 heads.
Well, what chassis were the headers designed for?
If you're talking about the cheapo $200 shorty internet specials advertised for Dakotas and Ram trucks, then no- they do not fit an A body. The passenger side may, but the driver's side tries to take up the same real estate as the steering box and column.
here you go , dak 5.9 r/t
I would almost bet money they wont .
Look at the rear dump exit,,,,it is way back behind the rear port tube .
I think you will run into firewall clearance there .
Tommy
