Magnum Flywheel on LA 360?
Valiant1
Redford, MI
Does anyone know if a flywheel from a 5.9L Magnum engine can be used on a mid-70's 360? I heard that because bob-weights were different between the engines that balancers and flywheels were not interchangeable between the two. Is this true? Thanks.
yes..both externally balanced...both balanced differently
They are not interchangeable. The holes are smaller on the Magnum 'wheel.
In other words, less weight is removed to balance a 5.9.
Thanks. I guess I can sell that magnum flywheel that I have. NOS Mopar. I got rid of the magnum engine that I planned to use it with anyway.
