Logan
Any reason why I can't use the Edelbrolck FI intake manifold (PN 28155) on my Magnum with EQ heads drilled for LA intake? Perhaps (Magnum) accessory mounting problems? Anyone done this?
Having a competent tuner alter the factory programing so you can reflash the ECM using a hand held SCT Tuner will give you significantly more power too.
SCT hand held tuner just allows you to simply load a calibration file into the factory ECM. That calibration is setup by the vender that sells you the hand held tuner box.
You supply them all the details of your engine, trans, vehicle weight, etc, and they build a file to optimize the fuel and timing, and shift points if applicable.
You cannot make these adjustments on your own with the SCT hand held tuner box.
I assume he charges "per tune?" What kind of money are we looking at, here?
