Magnum head headers
Actual port matching headers are non-exisitant as far as I know. You can use regular port shaped headers without issue.
Are you using stock heads or the enginequest heads?
I have "LA" headers on mine...no leaks but I use the steel/composite one piece exhaust manifold gasket
The TTI headers will seal right up to those magnum heads. Not cheap, but they are worth it.
