The m1 dual plane is a great intake from 0-5000 I had one and it pulled great from idle to 5000 but had very little after that. It produced gobs of torque on the low and mid range but had very little after 5000. If youre putting it on a stock magnum with a stock cam or running something like a comp cams 268 duration or so it will be fine. Look up 5.9 Junkyard Jewel I believe it was Popular Hot Rodding this intake with a stock cam on a stock 360 magnum with headers had 300 horsepower but...it had gobs of torque I believe it was 420 lbs at 4800 rpm.
