[FOR SALE] Magnum Parts
MidnightSwinger
Woodland CA
Parting out the EFI and Accessory drive from a 97 magnum I just bought. Motor is a runner and everything worked a few months ago when pulled.
It has the 92/93 fuel rail, with built in regulator and return. Includes the rail, injectors and clips. $75
Bolt on serpentine crank pulley $25
Magnum valve covers, plug wire holders, and used MSD wires $25
Has the magnum manual steering idler pulley $25
Stock Denso Alt $20
Alt/AC bracket with idler $20
Water pump with lo miles $10
Coil bracket with coil $10
Jared, did you get a transmission with it? I need the kickdown cable and all of the little do dads between the throttle body and the lever on the trans.
I’m sorry, it was just the motor. I can snag that stuff for you next time I go to the yard. I might have the lever for the trans, but not the other stuff.
Also have a stock pan, with a like new low mile oil pump, and dip stick tube. No dip stick. $20
Make an offer on anything you can use or we can bundle it.
