[Found!] Magnum Valve Covers
go-fish
Looking for a Magnum timing cover. I've heard there may be differences in accessory mounting holes from early-90's to later models. This will be going in a 1998 Jeep Grand Cherokee Limited 5.9L.
If you have done a Magnum swap and switched over to LA w/p and accessories and still have the Mag timing cover laying around hit me up!
Also looking for Magnum oil pan and pickup & valve covers.
Best Regards,
Go-Fish
I have only heard and not confirmed that there were some differences on the very early Magnums. ‘95 should be good. To my knowledge all the 5.9L oil pans are the same across years and vehicles.
I’ve got one, can’t seam to post pictures in message so I’ll post them here.
Looks like I got the timing cover covered. Anyone have a pan, p/u, or valve covers?
Just realized that I cannot, unfortunately, use a truck oil pan. I am building a stroker engine for my 1998 Jeep Grand Cherokee Limited with a 5.9L. The oil pan is different that a truck pan because it has to clear the front differential. It's even different from a Ram 4x4 5.9L oil pan.
I am still on the hunt for Magnum valve covers.
You might be able to find a 5.2 Magnum pan for a Jeep GC too. All Magnum pans are alike as far as fitment to a 5.2 or 5.9. They aren't like LA motors where 318 and 360 are different. If you used a pan from an LA 360 Jeep GC, it would work for you if you don't find a Magnum pan. Good luck with the search.
:thumbsup:
