Howdy, Ive always run magnum motors in my builds but i recently came into a D150 with a 1979 360 LA motor.
What difference in power/economy should i expect assuming i removed all of the Smog accessories from the motor?
What i'm really getting at is, Should i still try to find a magnum to replace the LA or wil lthe LA perform the same with the Smog accessories removed?
The general consensus regarding the Magnum seems to be that once you throw headers, a good 4bbl intake and carburetor you can expect to be around 300-320 HP.
Is the same true of the LA? Or does the LA have internal things like Pistons ext that hamstring its power.
