AbodyJohn88
- Joined
- Dec 2, 2006
- Messages
- 150
- Reaction score
- 2
what changes need to be made to put magnum heads on a la360, also with a solid roller??
thanks for the infro brian. i think i read a car craft write up somewhere that u built a 408 stroker with just touched up rhs heads and a hyd ft cam. i think it made 485hp and 520lbft? iirc. how much would your fully ported la x heads, with springs just for a similar style hyd flat tappet cam run?? also how much more power do you think you could get out of that setup with a full ported set of rhs x heads and a larger hyd ft cam to match the heads..... i know its alot of questions but i apreciate all the help mr guru : ). after this ill defanitly get a set of your full ported rhs x heads, and a hydraulic flat tappet cam specd by you. so i can just bolt ev erything up and run!!
