Sixpack_Sid
Hi guys,
I'm swapping a 440 in my 360 Duster and changing all the seals and gaskets. And of course, while trying to take out the rear main seal it came out in pieces- the old rope seal. I removed the crankshaft tonight and noticed the 1 and 2 caps were switched and that the notches in the connecting rod bearings didn't line up either. Is this a problem, should I be worried about putting it back together that way? Did it come from the factory that way, or did someone tear it apart before me and put it together wrong?
Thanks,
Dan
Thanks,
Dan
