1wild&crazyguy
Banned
makes you wonder if all supposed r & d 'so to speak' was all just dribble...
http://www.forabodiesonly.com/mopar/showthread.php?t=33223
1st the #'s on the magnums are high on the intake side for any other tests I've seen as 'stock' or 'bowl blended and nothing else', while the exhaust is average to lowish as well. Besides saying lil about the work done to the exhaust ports to go from 132 to 190's??, but he then mentions some j heads he did and posted the #'s as follows...
.100 91 89
.200 184 133
.300 222 176
.400 239 191
.500 283 196
.600 276 201
now that is a fk's up port to be losing that much velocity/flow, I mean...see how it's unbelievably massive till .300 and then fizzles out till .500, then picks up stalls?
The .100, .200, .300 #'s seem bogus/bs to me.
I bet they really shut off at .450 lift, no matter where the concentration went to 'low lift or what, how do you pick up over 100cfm from .100-.200 and then only another 48cfm from .200-.300, and then only 17cfm from .300-.400....and then miraculously gain 44cfm again from .400-.500?????
my point is the short turn is pretty jacked to stall out, especially that low of lift and then come back.
I usually have only seen this at or above .5-.550 lift.
I just saw this and am posting my initial thoughts, while I already knew the j heads are better, just suspicious of the numbers since I've seen slightly higher #'s on the mag exhaust but lower numbers on the mag intake, and with a 5 angle VJ..
You guys have any thoughts on this?
.100 91 89
.200 184 133
.300 222 176
.400 239 191
.500 283 196
.600 276 201
