Making Progress
george joseph reid
Deming New Mexico
New trans and converter are in starter and some wiring next. The fender wells hang a Wee bit low but when I get it back on the ground I think some heat and a jack will get them up. I will have to notch the T Bar outer support to run an exhaust, then fab it back together. Will get some pics as soon as I get in WIFI range. Now I can measure for a drive shaft.
Fender well
Very nice that is alot of header in a small space couldn't have been easy fitting those lol
Are putting inner fenders back in or leaving them out?
Actually the hedders come in and out easy. The car came as you see it cut up. I will run some bars from the firewall to the front of the frame with some down bars. I dont know why the PO cut that much out? Not really needed. Just going to clean up some of the mess and add structure where needed. Like I said I think a torch with a Rose Bud tip and a floor jack will tweak the collectors up and then there should be room for some pipes and mufflers dumped in front of the tires. Gonna be LOUD for sure.
