Ramcharger8314
Member
I bought this new and never got around to using it. It comes with the original box and instructions. Retail price at most speed shops is from 525 dollars to 551 dollars buy mine for much much less. Here is the description.
This is a bolt in and hook up a power and ground wire system that doesn't require a lot mechanical knowledge to hook up it doesn't get any easier than this system as far as hooking it up to work because it works in conjunction with your current ignition you are already running look at the wiring diagram of the pic I posted its that easy hence the EZ name.
Mallory HyFire 6EZL digital CD ignition features no connections to the vehicle's wiring harness. Power up and go. High output multi-spark ignition system. Built in easy to adjust digital rev limiter - 4,500 to 12,000 RPM - no expensive chips required! Latest microprocessor-controlled circuitry Easy to install. Lightweight aluminum housing = maximum heat transfer. More performance and lower power draw. Quicker acceleration and throttle response. Works with points, OEM or aftermarket electronic ignition, or magnetic crank triggers (exc. hall effect). Digital performance at analog prices. I decided to use the E core coil that came with this system Mallory part number 30450 costs 90.97 at Summit that is in the picture so you will have to replace it. I was asking 300.00 im now asking 200.00 plus 15.00 shipping without the E core coil in lower 48 states. Parts are located in Shallotte NC on the NC coast near the SC border.
