[SOLD] Mallory Tachometer with Rev Limiter & Shift Light
monc440
Active Member
Motor City
I was saving this for the Fury build but it will not work with my V10 Dodge PCM so I'm going to let it go.
11,000 RPM Tach, 3 inch face, adjustable shift light and adjustable rev limiter.
This is the easiest way to install an adjust able rev limiter on your car and it works great. Look on you tube to see how easy they are.
I have had this tach in storage for 20 plus years and used it on my last Dart build. I pulled it before I sold the car because they are hard to find and work so well. I loved it because I could have the rev limit set for myself but if I let someone else drive the car I could turn it down with just a twist of the knob.
Asking $150.00 OBO
