Mancini rear xhd springs
ir3333
ontario,canada
i have been through lots of rear spring posts and Espo seems to be highly regarded.
Have any body used the Mancini A body XHD rear springs?
how do you like them and how high are they....?
I have them on my 67 Dart and they are firm but not harsh. I would say the 1" above stock is correct. I did have to move the rear spring bracket forward a 1/2" to get the shackle angle correct. I have stock Monroe gas shock and no wheel hop.
I bought them about 10 years ago and used them up until last year,, from the posts I read now they must have been re-calibrated...mine were very stiff and still had wheel hop....
Isnt wheel hop usually pinion angle? Sure a better spring will help but if your getting wheel hop its usually pinion angle.
Wheel hop is more so the power or over powering the car suspension. The suspensions short coming, IE; pinion angle wrong only add to the problem. If your experiencing wheel hop, and everything like the pinion angle is correct, then look to the springs and shocks.
