[Found!] Manual Brake Rod for 74 Duster
72DMag
Pittsburgh
Going to manual brakes need the manual brake rod that will work with a 74 duster. I thought I've read that 73 and up are different but don't recall now. Will need shipped to 15417 Thanks!
Correct me if I'm wrong cause I am not very knowledgeable regarding this. But I thought there was only 2 lengths. A body and b body. Unless you buy and adjustable one but that's aftermarket. I thought the connection was changed somehow on the 73 and up a bodies. Again I could be mistaken about all this.
We r putting on a 1.03 master cylinder on the 74 duster from a dodge Aspen using dr. Diffs. 4 to 2 bolt adapter plate.
I’m parting a 73 dart sport and pulled the double reservoir master with the bar leading to the pedal. Is this what your looking for? Either way I can pull the pedal and assembly if you need that.
I have a couple of manual brake push rods.
They are 6 3/4" overall.
Start a conversation if interested.
Thanks! John
