Manual drum to power drum help
Dartncharger
Gang I am changing (or going to try) from manual drum brakes to power drum brakes. I can pick up a rebuilt booster/master for around $110...
SO, what else do I need to convert over, a different pedal assembly? Pedal bracket?
All help appreciated
Greg O
Actually it's the cheapest.
Rock Auto is $152
and an advertiser in Mopar Muscle sells for $395 (!)
Working on a 67 Dart
Judging from the pictures on Rock Auto, you are going to need the power brake bellcrank and bracket that mounts the booster and acts as the pedal pushrod. Should be able to get one from any '67 up power brake equipped A body. It mounts between the pedal assembly and the firewall and has provisions for the widely spaced booster mounting studs. You may also need to drill 4 holes for said studs. The pedal assembly itself should be fine. Hope this helps.
