[SOLD] Manual steering boxes
Oldmanmopar
Going left turning right
Danielsville Pa. 18038
These are from a-body cars. $85.00 each shipped anywhere in the lower 48. There are 4 as of now but one might be sold already. As is no returns Pay pal [email protected]. Danielsville Pa.
All manual boxes in muscle era mopars were aluminum, look at the pics and see they are aluminum.....and I believe that there was only one ratio - the fast ratio cars simply used a longer pitman arm to increase the "Throw".
All manual boxes in muscle era mopars were aluminum, look at the pics and see they are aluminum.....and I believe that there was only one ratio - the fast ratio cars simply used a longer pitman arm to increase the "Throw".[/QUOTE]
RIGHT & WRONG.
The steering ratio was changed by using a different worn gear & sector shaft, not a different pitman arm.
yeah - you may be right - too much uselsess info in my head, some gets forgotten! I might be thinking of the power boxes having only one ratio....
RIGHT & WRONG.
Tight and wrong. The steering ratio was changed by using a different worn gear & sector shaft, But AAR Cudas and T/A Challengers used a different Idler arm and Pitman arm
...16:1 until '69?
...24:1 from '70 on? but you could order a 20:1 from 'ma mopar parts dept
...just what i've been told
