MOPARCODY
Ive had a pretty much stock 904 with good clutches and a shift kit in my 65 dart for a while. the trans has about 1000 passes on it but its starting to let go. im thinking about building a trans with a brake and manual valve bodies, id like to keep the forward pattern
which valve body should i use?
i also have a 3500 stall hughes converter im thinking about replacing with something more aggressive.
car has a dakota rt short block with eddy heads air gap and the 380hp mpp crate motor cam. weighs 2800 without me in it. 3.91 gears with a spool and a 28" tire
