Not sure what one does with the linkage and more specifically the lever on the valve body on other manual setups, but with the TransGo TF-3 you can run the linkage setup as is for variable pressure (softer shifts at part throttle up to firm at wot) or just remove all the linkage and wire the lever fully back so the shifts are firm all the time.
