gashaller
Member
is it ok to use a reverse pattern manuel valve body for street use, I am changing from a 904 toa 727 I have a 71 dart swinger w/318
People do but be aware that most manual valve bodies don't have low gear braking
Mine is that way. If I live long enough to get the 42r / A500 project going, I'll use a different valve. I don't HAVE to have a reverse pattern. If you are "concerned" you could always build a simple lockout for the shifter which would prevent slamming neutral from 3rd on a forward pattern.
The problem isn't from accidentally slamming it into neutral. The problem is mainly related to 727's only and is because of no low gear braking you can over speed the front clutch carrier if you downshift to low gear. That can make the front drum explode like a grenade. Due to the smaller (compact) diameter of the front drum in a 904 or A500 they aren't as prone to exploding
Sure is been running one for years..
Manuel valve body is clearly a Mexican shifter!!
Thanks for the comments. I just meant that a forward VB "with some shifters" is easy to miss and hit N when getting frisky.
Does this even make sense?:violent1:
If you know the difference between Manuel and Manual it does :banghead:
Point in case... A FPVB will not work with a factory shifter. You need a RPVB that hits the detents.
Factory console shifter? I have a forward pattern MVB but have a column shift.
