Any idea what the markings on the pinion gear mean? Just got this from Dr. Diff...
2.77 should be your pinon depthAny idea what the markings on the pinion gear mean? Just got this from Dr. Diff...
Where is that measured from on a 489 case?2.77 should be your pinon depth
www.forabodiesonly.com
Like said above its measure from the center, but i quite doing it that way years ago because the pattern would never come out right, so i aways start with a .30 shim, unless your doing something like 5.13s and then you need more shim.Where is that measured from on a 489 case?
I was told to use the pattern to set the depth, using the old pinion's shim as a start (trial and error). Then once depth was set, set the preload on pinion, then finally the back lash
I am swapping out an open 2.76 for a new SG 3.23. The old pinion had a .34 shim and i am using that as a starting point for set up this weekend. I think i will try the "trial and error" depth method and see how it goes.Like said above its measure from the center, but i quite doing it that way years ago because the pattern would never come out right, so i aways start with a .30 shim, unless your doing something like 5.13s and then you need more shim.
The gear is a new 3.55,,,,my pinion bearing preload was at the max,,,,,but I didn’t want to waste another crush sleeve to get it perfect .
Tommy
oh come on.. i wish i had that tool when i did mine.. i figured they were a lot more expensive i think i had the carrier in and out like 10 times...Pardon Our Interruption
www.summitracing.com
