Its been sitting inside. People I got it from had taken the heads off to put oil in cylindersto keep it loose. When I got it it was locked up, but did not take a lot to get loose. Did not use anything extra for leverage and did not have to stand on it. Engine is loose now to where it turns over with one hand on balancer. Cylinder walls have some surface rust that comes off with brake cleaner and a maroon scotch-brite pad, and rust is not completely on all the cylinders. Going to rebiuld it back to factory specs as close as possible with new pistons at least cause of that, not sure about stock CR yet, may dop it one full point. Rods will get reconditioned and crank checked out, along with all the usual rebuild machining. Like I said this won't be a track warrior, but I do want it to last and move climb its way out of a wet paper bag. The 340 has more than enough ooomph on its own with some minor upgrades. Thanks.
