coffeedart67
Have a new master cylinder and have a few questions. The new master cylinder is Cardone 13-1323M, it has a different lid than both of the previous master cylinders did, the previous master cylinders had what I could best describe as double hump lids, with a single bolt and a spreader bar (m shaped bar)to hold it down, the new one has a single hump lid. Is this the right master cylinder? The new master cylinder has a small tabon the firewall side to hold in the piston(I assume), do I remove this prior to installation? The previous master cylinder has it removed, the master cylinder that was before that one had a sheetmetal cup spanning two countersunk holes that are present on all three masters. What do I do?
Will get pics in a little bit. I searched for about an hour, cause I now I saw a thread with pictures of the same masters as I have, but couldn't find it.
Thanks
Aaron
Thanks
Aaron
