master cylinder questions
dodgedifferent2
southwestern, Ontario
I am in the process of doing the viper front brake conversion from mopar action using hte 11.75 rotor and the 92-02 viper caliper on my 1967 dart
The rear brakes on the 8 3/4 will be the stock drum brakes (c-body i believe it was from with 489 case)
I am wondering what master cylinder to use. The dart did not have a master cylinder in the car when i picked it up. However i do have a master cylinder with booster. On the master cylinder i have a casting number 3580095 and the booster has a casting number B811A
What is the master cylinder from and will it work using the viper caliper and rear drum
I will be finding a proportioning valve next. What can the FABO members tell me?
