Troub
67 Dart 270, 225 slant six
Manual system on the 67 Dart. Is there any gasket between the Master and the firewall? I don't have anything and always have a small sliver of the firewall opening visible on top when the Master is bolted up.
looks good,what is holding the bellows on? original has a lip it goes around
The top piece looks like it could be close?I agree, could not find a repop on that plastic with bellow. I found a usable one in a yard. Here is what DMT has. Mopar A B E Body 62-76 BLACK 3 Piece Master Cylinder Gasket Set DMT | eBay
That is darn crafty. What did you use to cut it out?
Did you use any sealing agent at all and did you cut it any wider than the tracing at all?Total cost into this gasket? $0.0
Hey 72, used your idea today and it worked like a charm. Gasket made and as you said, the price is right! $0.00It's the same as the factory piece. But the don't make that either anymore. It's some type of nylon or plastic? So I used a laundry bottle. Boot goes thru the gasket to hold it in place.
