I could use a little help on this one...removed the power brakes in my duster and installed the master adapter/master and installed a adjustable brake pushrod...all in all pretty straight forward...BUT.. my pedal seems a little more firm than I would like..It also seems to have some difficulty returning after depressing.. It does come back..but not all the way the brake pedal and the clutch pedal were NEVER even on this car..I did make sure the bolt was not too tight on the pedal..I bench bled the master pretty good as well..I will bleed the brakes .but figured air would give me a soft pedal?...has anyone else encountered the same issue as me...? what was your solution.. ? any recommendations.?:burnout:
