prodart340
just picked up a standard bore 340 and was wondering if anyone could tell me the maximum allowable bore size for standard without getting "to loose" in the cylinder
.............. run as high as .010"-.015" on dirt track motors...... Some of them loose motors are some of the best runnin ones you'll ever build.
after hitting the cylinders with a ridge reamer, I get a cylinder size of 4.045, so is that too loose for a 410" build?
Yeah, but I bet they won't last long on the street that way. And don't forget TAPER. A lot of taper will work the rings to death. A quick look in my old '70 shop manual shows these factory specs:
stock bore 4.040-4.0420
max out of round .005
max taper, .010
Piston land clearance .019--.027
Clearance, top of skirt .0005-.0015
These of course for stock factory pistons
I wasn't puttin up a arguement....just sayin what I have seen done.
Neither, I. I've "pushed the limits" a little here and there. Biggest things I do is ignore valve guides, just put in better seals and run 'em.
