SilverFish
I've never been a fan of running more than a .030" overbore on anything, anybody else feel nervous about a .060" overbore on a small block Mopar? Especially if it's stroked???
It depends on the year. the 70-73 date coded 360s were cast off the same mold as the 340. Most of them can go a LOT over. I personally have gone .120" over with one and .100" over with another. Sonic checking of course is a must, but the earlier 360 castings have a lot more meat in the core. .060" is just fine for any of the 360 engines. If companies make .060" over pistons, you better believe the engines will go that far safely.
u'll b fine.
.060 over ain't sht.
sometimes you can get by but at least now a days with the better head gastets and or orings as mentioned above you can get by, but have it sonic tested 1st.
.060 is to much for small block mopars. Because of the weak ten bolt pattern heads you will continue to blow head gaskets unless you have the cylinders o-ringed. I know from experience cuase in the early 70's I had mine bored .060 over and trw 12 and a half to one pistons and was constantly changing head gaskets.
Howard
I picked up a 72' 340 block that was in a machine for about 20 years. Somebody brought it in and had it gone though and never came back and picked it up. It got shoved in the back and forgotten about. It has crank, cam, pistons .040 over and a timing chain. The bores look kind of rough and I don't know if they will clean up to uses the .040 pistons. So I might have to go to .060 over. I should be ok to punch it out bigger? I'm not planning on a radical rebuild. Just a good running moter with a little pep.
It might be ok but I wouldn't even think of it without sonic testing it. In fact if I have to go more than .030 over I sonic test them. Sonic testing is the only way to know the limits of it.
raced a .060 340 for ever.....with high old heavy 12.5 trw pistons...
have a 360 that is .060......have never thought twice about going .060
Dugans in Riv.,Ca. $80. (12) reads per bore,quaility work-always. Because mine will be raced, who's won't?,I'll using "Hard Block", in a half-fill. Ateam:cheers:Can you read man--its been answered, Sonic test is like $125-$150, otherwise you are gambling
Well like hcarr said you only have 10 bnolts and if you also go high compression it has always been a weak link, but the cometic gaskets as compared to old thin metal stampings help a bunch.
It is also i nthe old Direct Connection Mopar Bible too, that they recomend a racing gasket and or o-rings above 11.5 and the bigger you go this also has an effect on your static ompression too.
but good point and question.
My 419 stroker is 1975 360 bored .085 over, walls sonic checked, W2 iron hds & ARP head studs with Cometic gaskets. Only 10:1 CR but no problems so far. ususally runs 180-195 depending on ambient temp. Made 537 HP.
