moparjeff
Anyone know the max back space and wheel and tire combo i can get by with on my 69 dart with factory 8 3/4 rear and leaf springs relocated inboard. and should i install offset shackels? ty
Gonna have to get your terminology straight first. If you've done a 3" spring relocation, i.e., moved that springs to the frame rails, then you don't need offset shackles. It's an either/or proposition. A 1/2" offset is just that, it uses 1/2" offset hangers and shackles to move the springs a 1/2" inboard.
Either way, the biggest tire you can fit in a Dart with the stock wheel tubs is a 275. You can get that with a 1/2" offset, the 3" relocation doesn't get you any more space without a mini-tub because the stock tubs are the limiting factor after just a 1/2" offset.
So, do you have a 3" spring relocation? Have you done a mini-tub? And are you still running the small bolt pattern (5x4") axles?
a little under 1/2 inch clearance from lip to tire.
curious - 3" relocation but no mini tub... why not?sorry about that, no mini tub, 3 in relocation, big bolt, right now im running a 8' weld with 5 1/2 backspace with 255/60/15 drag radials, would like to go with the weld rts wheel 8 inch with 275/60/15 if i can without mini tub or rolling my lips. ty for the help.
